Modelling a fish hook
I am very new to SU. I would like to try and expand my skills by modeling a fish hook, and then eventually model a fly fishing fly.
I have made several attempts, but the barbed end is beyond me. I would really like the barbed end to flow smoothly into the hook. Hooks are made from continuous wire.
I have also done my best to search the forums for relevant topics.
Any pointers to relevant posts or other help will be greatly appreciated.
I think I have uploaded my latest attempt.
Thanks,
T
New Hook.skp (316.8 KB)
Would this play for you OK?
DaveR,
Heck yes. So what did I do wrong and what did you do right?
Thanks,
Tom
I wouldn’t say you did anything wrong or I did anything right. I just did it slightly differently.
I drew a centerline for the hook which ends at the start of the taper. I initially traced over the image to create the centerline. This was used as a path for Follow Me. For the taper I used Push/Pull. I toggled on creating a new starting face by tapping Ctrl (Option on Mac, IIRC) and then scaled the end down. I made the hook a component ensuring it was marked as Solid in Entity Info.
For the barb I started with a cylinder drawn vertically, I tapered the top of it to make it pointy and then using Move with Autofold (Command on Mac, I think) I moved the top of the cone-ish shape over to make it sort of barb-like. The bottom of the cylinder extended down inside the hook. I made it a solid component, too. Finally, I used the Union tool from Bool Tools 2 to combine the barb with the hook. You can use Outer Shell which is native. I prefer BoolTools2 because it respects components while the native Solid Tools don’t.
Here’s the file. You can play with it.
New Hook.skp (762.6 KB)
Thank you so much. That is super helpful.
Tom
Dave has given you a great method and this might be a touch more complex than you want for something so small but I got interested in the shape so here’s another method for making the barb.
Box,
That is super. It is almost how the barb is made. I don’t have all those extensions (yet?). I am trying to stick with native tools for the first few months of my using SU. But wow, that is pretty dang nifty.
Tom
