250114_display .skp (318.3 KB)
I can someone kindly let me know the simplest method to use when modeling this display attached, it has curve edge face on top profile and radius on sides.
The model is to scale.
probably like that.
I’d make 2 volumes (solids), one of the global top view, one of the side view, then I’d intersect them.
other than that, it’s really straightforward.
oh yeah, here as well.
minor things really.
pretty much the same way.
you can keep cutting parts using solid tools.
this is making the “outer shell” of the object.
now if you’re planning on building an exact replica in your model, you’ll need to add all the extra elements piece by piece.
No worries I’ve figured it out the subtract tool !
in builds like that, it pays to copy your object a few times.
one is the “main assembly” object.
that one will be cut to pieces to make the top transparent part.
that one will be used to add another piece…
you don’t need to work everything out from one single object in one single step. only the result matters ![]()
