Your file shows a lot of errors when I open it in SU 2021, says it’s fixed them, but still shows only the part of your model shown in your image above.
I have View/Axes turned on, but can’t see them, and when I draw a line from your component origin to the model origin, it still doesn’t show them at the other end of the line.
Your file has become corrupted.
The error message after the fixes are made shows:
Results of Validity Check.
The plane equation for CArcCurve (1139215) not valid.
- fixed
The plane equation for CArcCurve (1139441) not valid.
- fixed
The plane equation for CArcCurve (1140002) not valid.
- fixed
The plane equation for CArcCurve (1140115) not valid.
- fixed
The plane equation for CArcCurve (1143646) not valid.
- fixed
The plane equation for CArcCurve (1164233) not valid.
- fixed
The plane equation for CArcCurve (1175107) not valid.
- fixed
The plane equation for CArcCurve (1181847) not valid.
- fixed
The plane equation for CFace (1293954) is not valid - fixed
The plane equation for CFace (1294013) is not valid - fixed
The plane equation for CFace (1294020) is not valid - fixed
The plane equation for CFace (1294053) is not valid - fixed
The plane equation for CFace (1294085) is not valid - fixed
The plane equation for CFace (1294132) is not valid - fixed
The plane equation for CFace (1294358) is not valid - fixed
The plane equation for CFace (1294372) is not valid - fixed
The plane equation for CFace (1294482) is not valid - fixed
The plane equation for CFace (1294534) is not valid - fixed
The plane equation for CFace (1294585) is not valid - fixed
The plane equation for CFace (1294598) is not valid - fixed
The plane equation for CFace (1294631) is not valid - fixed
The plane equation for CFace (1294769) is not valid - fixed
The plane equation for CFace (1294802) is not valid - fixed
The plane equation for CFace (1294896) is not valid - fixed
The plane equation for CFace (1294999) is not valid - fixed
The plane equation for CFace (1295034) is not valid - fixed
The plane equation for CFace (1295074) is not valid - fixed
The plane equation for CFace (1295081) is not valid - fixed
The plane equation for CFace (1295109) is not valid - fixed
The plane equation for CFace (1295242) is not valid - fixed
The plane equation for CFace (1295292) is not valid - fixed
I can see quite a number of components listed in the component browser but only some of them seem to have content.
I re-tried opening the model, but I still see only one small cluster of 9 components, and even more bizarrely, this time the axes do appear, but the red axis is kinked - I’ve never seen that before!
I’ve tried a plugin called RescueMyModel v12.rb, but that doesn’t seem to help - the file is still corrupt and shows no more than the original.
RescueMyModel v12.rb (4.2 KB)
Sorry - I can’t see anything I can do about it.
Maybe @colin can?
