Model Turning Green
When i move my design to LayOut the color of my model turns green but when i edit in 3d like rotating in the LayOut application it turns normal and when i click outside the layout and it locks in it turn green again
(the normal color is when i try rotating)
and this is when i try rotating it
it looks normal but when i leave it it turns green
Hi there.
ok, first,
it is, indeed, green.
second, could you share the file maybe ? that was we can rule out ideas, is it your file, is it your machine, is it an actual weird bug… :slight_smile:
if it’s too heavy, you can use a hosting platform like this
and share the link with us
A JPG isn’t really enough to go on, especially not seeing more of your screen.
Post the LayOut file. Drag it to a reply window or if it is too large use a file sharing service.
Are you still using 2020?
Is the rectangle view of SKP filled green?
