Model turns blue when sent to layout
When I send my model to layout It appears with this blue all over it. It only shows that way in layout.
Here is how it looks in my sketchup model. Yes the sky is turned off in my model.
Any help would be appreciated.
I don’t know for certain this would cause that, but turn on monochrome mode and check for reversed faces.
It would help if you shared the LO file but from your screenshot it looks like possible z-fighting (two faces sharing the same location or very close together. And/or the model is at a great distance from the origin.
I am wondering if it’s regular z-fighting, but LayOut is more sensitive.
Were you set to Hybrid for rendering? How far from the Origin is the geometry?
You could give your wall some thickness, and then z-fighting is less likely to happen.
