Model has zoomed out and i cant find it
Please fill out your profile and share the model you are having problems with.
Press Shift + Z or the icon with the magnifying glass and three arrows around it. If this doesn’t work it’s that probably you have geometry far away from each other. If that’s the case you can share the model, I sure one of the members of the group will be able to solve it. And do as Aaron said, fill out your profile so we can help you in a better way.
Changing the view from parallel to perspective and then using the Zoom Extents function sometimes also helps.
Due to how it works, parallel projection can lead to the view camera being very far from the model contents, making them too small to see. Zoom won’t fix this unless you first change to perspective projection, which handles the camera differently.
