Model data too big
Help me please. My file is very big.
21 million edges!
Don’t download everything you find in the 3D Warehouse into your model. Learn to search for or create low poly models.
You're absolutely right. This file is very important to me right now. What should I do? How can I recover it?
Recover from where? Open the file, delete the high poly models you inserted, then Purge, and then search/create low poly models to replace the deleted ones.
It’s not necessary to apply ‘markdown code’ to what you write, that’s not what that code is for. Plus, it makes your text harder to read.
I didn't do it intentionally. I'm very short on time right now. I've cleaned the curtains, plants, and sculptures, but it's still not fixed.
Stop formatting the text, it’s illogical in this case.
Did you use the ‘Purge’ command after deleting those models?
Without deleting anything, just running Purge on the original file and it deleted 62 components out of 187, which are in the file.
Yes, I reduced the size of the file I created, but I’m still experiencing the same errors.
Get rid of the extraneous stuff like this:
Purge unused stuff again.
Reduce the excessively large textures to some more reasonable size.
Consolidate the identical materials, too.
Simplify the high-poly objects.
The file shows it was saved in SketchUp 2023. Is that a cr acked version?
Where have you been saving the file while working on it?
