If ambient occlusion is active when I make a component, either one of two things happens:
- The new component object becomes a black silhouette until I click another tool, click negative space, or hit escape.
- Or a chunk of the SketchUp model window blacks out.
This is using the new graphics engine (AO isn’t available in the old one)
It is a repeatable bug
I’ve toggled AO on and off to determine it is the culprit
I’ve also toggled between graphics engines and it does only occur with AO turned on
I don’t seen any current topics about this issue, is it known? Or any helpful workarounds beyond “Don’t use AO if it’s causing a problem”
Mac M4 Sequoia, SKP 2025
