Made a copy and flipped it to finishmy part. I had the copy selected and aligned it with the original. When a zoomed out it was 1/16 off. Now when I try to select, the whole part is selected not just the copy I need to move.
How do I move the flipped copy 1/16 then add it to the original so I can 3D print??
I’m not sure if there is a way to use scale to mirror something at the same time as making a copy. One way to get what you wanted would be:
Select your initial half, right-click Make Group
Copy
Paste in Place
4 Scale horizontally to -1 (which will just scale the copy)
Select both parts, right-click Explode.
Left to right select where the two join, and Delete
To 3D print you would want to have the object grouped, and as a solid, and I think that some parts of the model are not going to be solid without some changes.
I intentionally kept these tubes solid, as making them hollow with thin walls ruined about 10 previous drawing and I was told I needed to start over. What is not solid about this model?
I though I would group when I am actually done, (Im so close!) and then see about getting it checked for solid…
Ok. I finally got what you mean. In my screen shot, it was flipped the wrong, after making themirroe image, the part should look like a D that fell over. I got it to align after fiddling with it for some time.
