Medeek wall making parapet walls
bluecanyon.skp (2.3 MB)
TRYING TO MAKE PARAPET WALLS 3” HIGHER THEN THE HALF OF ROOF i HAVE TO LOOK LIKE THE NON MEDEEK WALLS I HAVE IN THE ONE MODEL
Even though you dont have a wall seperating the space you could draw one and make a door opening all the way across. Make the long exterior walls in two sections so you can raise them all. Then do another monopitch within the raised walls.. You can clean up using the subtract feature. Ive found that the easiest way to tackle odd framing.
And please turn of your caps lock, it’s considered shouting!
Ivan, I don’t quite understand your solution. Any chance you could show in a quick diagram or screenshot?
This is the OP SKP file posted above.
Shown is what looks like a monopitch roofin the Medeek model with the part he cant figure out open. I was saying raise the walls on the three sides then make another monopitch within those walls. The Medeek extension is very powerful but there are odd framing situations like this that take a little creativity. Medeek has a subtract feature that deletes objects in a assembly that might need a little cleanup.
Ok its rough but I worked on the model. Updated SKP is attached.
bluecanyon1.skp (3.7 MB)
Thank you so much for your reply.
This will be useful to me in the future.
