Version 1.3.2 - 07.11.2021
- Enabled subscription and permanent licensing.
- The License tab of the Global Settings now displays the license type.
Version 1.3.3 - 01.11.2023
Hello,
Thank you for your hard work. Are you planning to add some Europlug standard to your extension? USA and UK is fine, but AC power plugs are different and it would be nice to cover that topic. Have a look how many countries use round plugs and sockets Mains electricity by country - Wikipedia
Type D (BS 546 5 A)
Type E (French) CEE 7/6 plug & CEE 7/5 socket, 16A
Type F (“Schuko”) CEE 7/4 plug & CEE 7/3 socket, 16A
CEE 7/7 plug, (combines earthing methods of Type E & Type F)
If you would like more info, just let me know. Best wishes
Michal
If I get enough requests for the European standard I will work on including it in the plugin.
Version 1.3.4 - 06.13.2023
Previously electrical fixtures could only be inserted into walls that were “groups”, with this update the wall assemblies can be either groups or components.
This update per customer request.
P.S.
I will still need to update the other misc. electrical fixtures (ie. panels, low voltage, safety, heaters, vents, low voltage panels etc…)
Version 1.3.4b - 06.15.2023
Version 1.3.5 - 09.29.2023
Version 1.3.6 - 10.04.2023
The text and symbol vertical offsets are driven by the global settings however these two parameters can now be adjusted separately for each individual outlet or switch.
This update is per customer request.
Version 1.3.7 - 10.14.2023
Added per customer request.
Version 1.3.8 - 11.22.2023
Version 1.3.8b - 11.23.2023
With this update one can scale the 2D symbol superscript of the electrical symbols and make them more visible and legible when exporting to Layout, PDFs or paper.
Version 1.3.9 - 01.08.2024
As always, you’re doing amazing work. Thanks for all you do.
Version 1.4.0 - 01.12.2024
Note, that previous custom wire libraries will not be compatible with this latest update. If you have an extensive library already established please contact me directly with step-by-step instructions on how to bring an older wire library into this latest version of the plugin.
The dimensions for the OD, wall thickness and bend radius were taken directly from CANTEX and JM Eagle literature, and should match exactly the standard specs for SCH40 PVC in the American and Canadian markets.
Aaaand here comes a Medeek plumbing extension ;D. Thanks Nathan!
I’m looking for good models of electrical pvc components in the warehouse like of the electrical component below:
I’m not finding very many.
Itd be great if the floor extension was finished before starting a plumbing extension.
Trust me the Floor Extension will be out well before a plumbing extension is even conceptually devised.
Version 1.4.1 - 01.31.2024
It turns out the outer diameter and bend radius of schedule 80 conduit is the same as schedule 40, only the wall thickness is different. I learn something new everyday.
