Hello,
when editing a component the measures change position.
When zooming in, some of the numbers disappear.
Any ideas ?
How about uploading the SKP file so we can see exactly what you’ve got and how you set it up?
What version of SketchUp? Please complete your profile.
Hi Dave,
i´m on SU 2019 pro.
the Component is part of a bigger garden, about 162 MB.
when exporting and opening the Component alone, the measures work fine.
Seems the bug comes from the main file.
Theres another bug in the file, when rotating the component some measures disappear (only the numbers) when zooming out, the number comes back.
How far from the origin is the model content?
This is due to a scaled component with dimensions inside the component’s context.
Say if the component is scaled down by 0.5. So will be the distance of the dimension towards measured geometry. If you open the component for editing the dimension jumps out towards its original position, twice the distance from the measured geometry.
Hi, thanks for your reply,
when re-importing the component into the drawing the measures disappear when zooming in, one by one.
