How do you make a measurement at a 45 deg angle to the drawing
Do you need to measure and dimension the angle?
There is no native angular dimension tool (you need a plugin for it) but you can measure angles with the ‘Protractor’ tool
Or do you want to create geometry (say two edges) at 45 degrees?
Example: select the edge > copy rotate it > type 45 > and hit [Enter]
Thanks for you help, I just figured it out
I just figured it out thanks for your help
