Materials problem
Hi … I have problem with materials in sketch up …
When I for example put wood materials on door it dose not show up … It is just show the color of wood
Can you help me I have project for graphics subject
Thanks
  1. Set your visual style to Shaded with Textures, if not already set.
  2. Check your model scale. Is it so big that the texture image becomes infinitesimally small. This can happen if you have made your model using Meters as the modelling unit while you have thought that you were using millimeters, for instance.
  3. Check for updates to your graphics card driver.
Anssi
hi
thanks so much , it was case 2
