I need to tag the material name in Layout.
It is possible to tag the area, but not the material, why? That would make interior design projects easier and lesser mistakes.
Thanks!
Thanks!
Are you talking about labels? Tags are something given to objects in SketchUp.
Your profile says you are using the free web version which wouldn’t give you access to LayOut. Maybe you could correct your profile since that information is useful in helping you.
One of the reasons why “layers” perhaps ought to have been retained. In CAD/BIM “tag” usually denotes a graphic symbol that identifies an object. It is almost synonymous or a subgroup to “label”
Yes, I’m talking about labels!! Wrong word!
You can click the small blue arrow that appears when you “label” an object and select face/area.
Yes, but this option allows to label the surface area. But i need to label the MATERIAL that is applied to the surface
Sorry, you’re right. I have asked for that in the past. It would be very useful. I would use it to tag hatch materials on my construction sections.
Might be the big NEW feature for Layout 2022 ![]()
