How do I make this clock round? (Huxley Wall Clock in warehouse).
It appears as a polygon.
Okay, thanks DaveR.
Once you’ve done something to a circle Like extrude it, you can’t edit the number of sides. You can however change the number of sides immediately after making the circle by editing the Sides field in Entity Info. Before starting to draw a circle you can change the number of sides in the Measurements window.
While redrawing is often easiest, sometimes you actually want to adjust the geometry.
Here is a quick way of adding more segments and then resizing the circles to match the originals within the existing geometry…
This will only work if the circles still retain their circle id and haven’t been exploded into individual segments.
Thank you! Very helpful.
