Made this a few months back and finally got my prototype in the mail. Ran some tests and I need to make some adjustments but am having trouble remembering how to use sketchup. Would you please help me do the following.
need to make the width of the cone 150mm
need to make the slots in the cone more numerous and 3mm wide.
Need the slots to extend lower 3mm so they meet the top of the bottom cylinder.
Need the slots to not extend so high. Maybe 3mm lower.
Ideally would like the slots to be 3 windows as opposed to one tall one for rigidity.( this ones way beyond me)
Making the cone 150mm wide is the easy part. For the rest I think the least work would be to redraw at least the cone with the openings the way you want them. You could draw one and use a radial array with Copy/Rotate to create the rest of them.
It’s right. the cone isn’t solid. There’s a surface missing between the inside face of the cone an the inside of the cylindrical part. I hid the outside of the cone so you can see that. Their selected here.
Hide the cone surfaces temporarily and then draw lines from the outside rim to the inside. I drew two lines and the face filled in. Then I deleted those lines. Then unhide the hidden faces.
Would someone please help me make some modifications to this design.
Instead of a cone, please make the angle of the cone steeper and then after climbing an 1.5" chop the top of the cone off making it flat like a plateau.
half way up the side ( .75") please make a 5mm ridge that circles all the way around the exterior.
Please make the cut outs 4mm wide this time instead of 3mm.
So, Roland, have you by any chance considered availing yourself of the copious instructional resources so you can figure out how to do this stuff yourself?
