Mac Warning
Should I be worried about this message that has just popped up on my computer?
05
what shows up if hitting ā€œLearn Moreā€¦ā€?
What version of LayOut were you using?
an early warning concerning the withdrawal of the OpenGL/OpenCL support for the next major macOS release?
Current - 2019.
which is 64-bit.
I wonder how far in the future they are referring to.
No, it’s all to do with future versions of Mac OS being 64 bit. I get the same message with Acrobat Pro.
I presume it does not affect anything now but is forewarning me that if I update my OS later this year, some software will stop working if it hasn’t been upgraded to suit.
What MacOS version are you running? It’s been 64-bit for awhile.
golden rule, don’t upgrade to the initial major release of everything… :yum:
In which case, why the warning? It says it will keep telling me this every month.
Mojave.
It is a rule I follow. I have only recently upgraded to Mojave some 6 months after release for just that reason.
Well, you shouldn’t be getting that message with LO2019 and Mojave. @trent, any ideas?
That warning is supposed to flag an app that is 32-bit, which is certainly not the case with LayOut 2019. I’m not getting the warning with macOS 10.14.3 Mojave on my Mac, which suggests it is something specific to your installation. I recall reports in the past of cases in which macOS mis-tagged an app as being PowerPC architecture, so maybe something similar has happened here. I’d try deleting and then reinstalling SketchUp and see if that fixes the issue.
HowTo: 32-bit or 64-bit Application?
  1. Apple Menu
  2. About This Mac
  3. System Report…
  4. Software
  5. Applications
  6. rightmost Column: 64-bit (Intel)
I presume the top one is SU 2019 but I don’t know whether that is also Layout.
That is just SketchUp. Look also up earlier in the listing:
Could by the new notarization obligation required for applications distributed outside the Mac App Store probably effective with one of the next macOS 10.14 maintenance updates?
open Terminal.app >> type the word ā€˜open’ >> drag ā€˜LayOut.app’ into terminal window >> hit return…
this resets the wrongly associated startup plist and the message shouldn’t re-appear…
you could also try it on Acrobat.app…
john
