The model weighs approximately 750MB
The project is very heavy and it won’t let me upload it.
If it is of any use, this is a screenshot that shows a large part of the model.
I could not find the information on the number of faces and edges, if you explain me again I would be very grateful and I could provide you with the information.
If your computer runs Windows (probably Windows 10 - but please update your profile as I asked earlier) then go to the Window menu in SU, choose Model Info, then Statistics.
Select Entire Model, and check the box Show Nested Components.
Si su computadora ejecuta Windows (probablemente Windows 10, pero actualice su perfil como le pregunté anteriormente), vaya al menú Ventana en SU, elija Información del modelo y luego Estadísticas.
Seleccione Todo el modelo y marque la casilla Mostrar componentes anidados.
El proyecto es muy pesado y no me deja subirlo.
750 Mb is a HUGE SU model, and as you say, you can’t upload it directly to the forum.
You can upload it to a file sharing service like Dropbox, OneDrive or We Transfer, make it public, then post a link here to the model.
I see in your screenshot a number of plants. They usually have large numbers of edges and faces. And other components you may have downloaded from the 3D Warehouse may be similarly detailed, and/or include overlarge textures.
To make your model more manageable, see SketchUp help with suggestions for how to simplify your model.
https://help.sketchup.com/en/sketchup/improving-performance
Get Google Translate to convert the text to Spanish if you find it difficult to understand written English.
750 Mb es un modelo SU ENORME y, como dices, no puedes subirlo directamente al foro.
Puede cargarlo en un servicio de intercambio de archivos como Dropbox, OneDrive o We Transfer, hacerlo público y luego publicar un enlace aquí al modelo.
Veo en tu captura de pantalla varias plantas. Suelen tener una gran cantidad de aristas y caras. Y es posible que otros componentes que haya descargado de la Galería 3D se detallen de manera similar y / o incluyan texturas demasiado grandes.
Para que su modelo sea más manejable, consulte la ayuda de SketchUp con sugerencias sobre cómo simplificar su modelo.
Obtenga Google Translate para convertir el texto al español si le resulta difícil entender el inglés escrito.
