Login in issue
127.0.0.1 is the loopback address, commonly referred to as “localhost.” It’s used to establish an IP connection to the same machine or computer being used by the end-user, which is typically for testing and development purposes.
You can try:
(a) Clear Cache and Cookies: Sometimes, clearing the browser cache and cookies can resolve the issue. This can be done through the browser settings.
(b) Delete Login Session File:
  • On MS Windows navigate to:
    %AppData%/SketchUp/SketchUp 2024/ and delete the login_session.dat file.
    * In versions 2023 and older the login_session.dat file is in the SketchUp subfolder of the path given above.
  • On Apple MacOS navigate to:
    ~/Library/Application Support/SketchUp 2024/ and find the login_session.dat file there or in the SketchUp subfolder, then delete it.
Change the version of SketchUp in the given paths for the version you are trying to log into. I wrote 2024 because your forum profile still says this version.
Then, restart SketchUp and try signing in again.
