Error Loading File C:/Users/tas/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe Failed to read RBE/RBS file. Error Loading File Fredo6_!LibFredo6.rb Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6> C:/Users/tas/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process' C:/Users/tas/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in module:LibFredo6_Loader’ C:/Users/tas/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>’ Error Loading File C:/Users/tas/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_advancedcameratools/actloader.rbe Failed to read RBE/RBS file. Error Loading File C:/Users/tas/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rbe Failed to read RBE/RBS file. Error Loading File C:/Users/tas/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_sandbox/sandb
Try this to start with.
Close all Sketchup and layout if you have any running.
Find the installation .exe or download a fresh version if you don’t have it. Select it then right click it and choose Run as Administrator (this is not running sketchup as an admin, nor is it the same as being signed in as an admin), follow the prompts and when asked choose Repair. Once done reboot your computer and see if you still get the load errors.
Thank you. I’ll try this now. Cheers
