Lines of outsides wall visible inside?
Hi Everyone,
I’m new to sketchup and have a question concerning the lines of the outsides of the wall that are visible from inside as you can see on the picture below.
It is even worse when I put my designs in a sketchy style.
How do I fix this?
Here is the sketchy style where you can see the lines very clear:
can you share your model? It seems like you have x-ray active or the material has transparency
(Edit) x-ray can’t be the problem
It looks like the wall panel behind the toilet-roll holder has either been given a transparent material, or it’s been deleted.
Fix it by selecting the incorrectly colored face and giving the wall material through Entity Info [or fix the wall material’s opacity as mentioned below**…], or if it’s missing then you can draw over one of the edges of that missing face - it should be auto recreated. If it’s reversed, select it and used the context-menu item to Reverse it, then apply the wall material onto it.
**The wall behind the WC also looks partially transparent, so check its material’s opacity…
PS. move the mirror off the wall slightly to avoid the ‘z-fighting’…
The material did have transparency, problem solved! Thank you!
Yes, it was the material that had transparency.
Thanks for the tip about the mirror!
