So, I was drawing these walls from a jpg, into a 2d floor plan, when I pulled them up i noticed only one wall was opaque and the rest are transparent.
-Back edges are off.
-Xray mode is off.
-I’ve tried to draw back in faces, but that doesn’t seem to work.
-Walls were grouped and tagged before I pulled them up, but I think its a tag issue.
I noticed some wall lines somehow ended up with the floor tag, but I moved the floor away and regrouped.
I’m new to sketchup and was trying to work slowly to get the organization set up so I think thats where I must have mixed something up.
well it looks like you applied two materials to the walls. one it transparent, the other is not.
off course the only way to diagnose this is to… share your file.
OFFICE INTERIOR.skp (628.7 KB)
Thank you!
Two different materials applied to the front and back faces on the transparent ones…
Same material applied to the front and back faces on the non-transparent one.
Here I’ve fixed your model with the same single material applied to all of the walls.
I also fixed incorrect tag usage and purged unused stuff from your model.
OFFICE INTERIOR purged.skp (594.0 KB)
Thank you Dave! That was really helpful! May I ask how you purged the unused stuff?
I used an extension called Purge All from Sketchucation because it gives reports like the one I showed in my previous post. You can also do the same thing without the report from Model Info>Statistics>Purge Unused.
