Why are my walls transparent or just lines
Hi, I am new to sketchup and slowly learning my way. I have started to build a model but what i am seeing is not solid walls. I have tried toggling K without success. Is anyone able to help with this please as I am completely stuck and can’t move forward.? I have attached a photo to show you what I am seeing. Many thanks
Looks like you got X-ray mode engaged, you can turn it off here:
hi Thanks for reply, i don’t have Xray on but i did use it when I started the sketch as i was using a floor plan to sketch over. I then turned it off.
Then check if you set the face style to wireframe. If so, set it back to Shaded or Shaded with Textures and you should be ready to go.
thanks I have now done that but still no walls. could this have something to do with when I imported the floor plan and changed the opacity in the little window (tray). I can’t work out how to get back to that window
Thanks. I have tried this but it only changes the background colour.
Please upload the model in your reply.
Allowing us to work with it will help us help you.
Like so…
As you are using the Web version, use the Download item in the menu that opens from the folder icon at the upper left of the SketchUp (not the forum) window. That will save a copy to your computer that you can upload here as @Geo suggested.
Could you have painted your walls with a 100% transparent color? Try the paint tool and choose a new color, see if you can paint a surface. Or perhaps the surfaces are erased, really looks like wireframe style. Post the model as suggested for a sure answer.
Sorry to bump a zombie thread, but was this issue ever resolved? I just found myself in exactly the same situation: traced a JPG floor plan, grouped the exterior walls, drew the interior walls with the line tool and grouped them, exterior walls extruded fine but the interior walls came out like they’re in wireframe mode. Tried toggling “k”, x-ray mode, wireframe mode, styles, tried selecting the interior walls and setting the material type but nothing changes it. I also had issues extruding the interior walls, if that’s helpful information.
[edit] ok, for anyone who comes after us all, it seems that my exterior walls and interior walls are tagged separately, and when i drew the interior walls against the exteriors, the polygons didn’t complete because I only drew to the wall and didn’t complete the rectangles.
Evidence of incorrect workflow. Don’t tag edges and faces, only assign Tags to groups/components.
So in your case, you can draw all the walls together but group the outer walls before assigning them a tag, then the geometry of the inner walls will still be complete and allow you to group and tag it.
Here’s a very simple example of what I mean. This way all the raw geometry remains untagged.
Tags
thank you!
You’re welcome.
