encountered no, I rarely export animation with a decimal in the line multiplier on my pc
So yeah, I tried, french version too, same problem.
I wonder if it relates to the classic decimal point on some non english version problem.
The line multiplier field still expects a decimal dot even if your computer is in non english (or american) parameters.
However, it won’t accept shift + ; to place a dot. it expects you to use the numpad decimal key.
If you don’t have one, you’re done. if you’ve remapped it to force a comma (as I did), you’re done.
(I also tried typing 0.5 elsewhere and pasting it but the field really don’t see key combinations)
I guess it would be an easy fix, simply have the field use the decimal symbol of windows and not the american dot.
ping to @colin who is probably eating turkey leftovers this weekend, so he can pass it on
The screenshot of the first message clearly shows that you can enter a value with a comma or a dot, since SketchUp indicates that you can enter a value between 0.25 and 100.
And in version 2022 it works.
I don’t know if there are any other decimal separators in the world apart from the dot and the comma, but it would be nice if SketchUp automatically accepted both, so that the user can choose what suits him best rather than having to look for the decimal separator set in the operating system.
Ping to @colin we’ve got a simple localisation bug here, SU expects a dot even if the PC is set to use a comma.
But won’t accept a shift + ; in order to make a dot. At least in the french PC 2023 version.
Mac is ok. so is 2022
Sure, IF you have a numpad. and your PC is configured to have a decimal dot.
Also, well, it’s part of the other issue.
The numpad decimal key should give a decimal symbol, not a dot. this is a very old problem in non-dot countries that has never been addressed by Sketchup. Every couple of years it resurfaces, and then, it’s not solved.
