Limited to 0,0000cm
Hello guys, Iam trying to push pull UP this face but it gives me this message.
Upload your model here (drag the .skp file into your post, if it is less than about 10MB, or else upload it to a file sharing service like Dropbox, OneDrive or WeTransfer and share a link here).
Please update your profile to show which version of SketchUp you are using.
The message means you are meeting another part of your model when you try to pushpull that face. Try tapping the Ctrl key, to display a + sign beside the push-pull cursor. That leaves a face behind and will allow you to push-pull past the sticking point.
You’re probably running into another face or a diagonal edge.
As the guys above have said, it’s nothing special, you’ve run into an edge. Here is one way to reproduce it, and the ctrl to pass through.
Offset
thank you very much! it works!
