I have a huge model with materials and I’m trying to render it in Hybrid for a large presentation.
My display options are set to low and my output on high but it still won’t switch over to Vector or Hybrid. Someone told me it would take an hour or so per drawing, but my wheel has been spinning for over 3 hours. Is there a way to get decent lines without vector or hybrid? Any help is appreciated.
The file is too big to attach but I can link it if necessary.
I am trying your file. It takes a while to even open. One thing that can take a long time is generating thumbnails for pages. I am trying Hybrid after making sure Pages is closed. So far it is still taking a long time to switch to Hybrid.
I’m worried that after 3 hours I waited that it’s a lost cause. It looks like export 2D graphic from Sketchup gives me the spinning wheel of death too. I’m not sure how to get this graphic exported.
Sheesh! A 325 mb SketchUp file with 78 million edges, there is little hope of vector rendering this. It’s also got some lost geometry way far from the origin. This poor model appears to be very bloated with high poly downloaded models. I started to play with it but it needs some serious time and effort put into cleaning it up. With some effort you may be able to tag classes of elements and control their visibility with tags, then use stacked viewports to make a vector rendered section of architecture, overlaid with a separate viewport for raster render of only plants and furniture. But it’s going to be slow going. Some heavy housecleaning is needed in the usual suspects, plants and way over-detailed furniture, here is a look at the heaviest objects in the model…
What you probably have done is build a forest of 3D trees. and a car park of detailed cars. Get rid of those. This without trying to open your model. Forget about Hybrid or Vector rendering, it works for a model with 1% of the geometry you have stuffed in.
Because the 3D Warehouse is so vast it is much easier to overload your model in SketchUp than in Revit where the number of available assets is smaller. 3D views in Revit are also resource hungry and quite the same modeling rules apply if you want to keep things going smooth.
Yes SketchUp can do 3D sections. But, Revit and ACAD would also have issues with such a large 3D file. Purge everything you do not need and save scenes in a way that makes the render efficient. Stacking view ports with a combination of raster and hybrid/vector would increase speed drastically. Minimize what “needs” to be vector and hybrid.
Raster quality only shows it’s jagged head when you are zoomed in, so also consider how you are presenting. All to often people complain about raster quality when they are looking at it as though you are looking at a 24x36 D sheet with their nose pressed to the paper.
