I’m trying to snap a dimension from one edge to another edge, along the Green axis…
The dimension just wont snap to anything other than a point,even if I constraint the dimension to a certain axis.
Is there something wrong that I’ve been putting up with for years? Or is this how LayOut is supposed to work?
The following is a Zip file is a video of what I am experiencing.
I struggle with it. I always assumed it’s a 3D thing, where the two ends snapped to are at different depths, which you can’t tell in ortho, as well as the separation in distance you can see.
It’s made me wonder what the search order is when LO hunts for points to snap to. Does it start near the camera and work it’s way farther away, or is it just some pseudo-random order that objects are saved/listed in the SU file?
@AK_SAM just watched your video again - you are snapping… if you pull parallel with the walls you get accurate dimensions - you can snap anywhere on that edge and you can pull accurate dimensions just by making sure you are pependicular to the desired dimension line.
