I am encountering a problem whereby the drawing appears exactly as I want it in Layout (X-ray with visible inside edges). But when I export to pdf or image, the detail disappears.
I have created scenes and styes in the actual SU file, to ensure the style is carried over to the end product. I have tried Raster, Vector and Hybrid.
I have attached 2 images to this post:
Screenshot of the style shown in Layout.
Screenshot when exported to pdf.
The project is confidential, hence I cannot share the full screen image.
In essence, I want the to pdf to appear as it does in layout.
So that’s a viewport from SketchUp and the model is 2D? If that’s the case, move the smaller rectangles above the surface of the large one a little bit so there is some separation.
It’s difficult to give you more direct help since we aren’t permitted to see the LayOut file.
Is your profile correct? Are you still using SketchUp 2022?
Regardless of settings etc, I cannot understand why the style appears as I want in the 3D model, then Layout appears as I want, but pdf does not appear the same as Layout?
