Layout - Rounded rectangles - adjusting the radius of the corners
Hi,
I’m using the rounded rectangle tool on LayOut 22, is there anyway I can adjust the radius of the corners?
At the moment the corners are very rounded but I’d like to be able to adjust this. I’ve tried the shift, option & command keys but those don’t seem to do what I want.
Here shows the size of the rectangle I’m after with the rounded rectangle inside. I’d like the corners to only be slightly curved.
Thanks in advance :slightly_smiling_face:
From the Help files:
  • Round the edges of any rectangle. Press the Up Arrow or Down Arrow key while creating the rectangle.
  • Change the rounding of rounded rectangles. Immediately after you draw a rectangle with the Rounded Rectangle tool, you can specify a radius for the rounded corners by typing a unit of measure and the letter r in the Measurements box. For example, to use a point value, type 10pt r, and then press Enter or Return.
https://help.sketchup.com/en/layout/making-rectangles
Once you’ve finished it the radius is set and you would need to make a new one to get a different radius.
Thanks Dave!
The up/ down arrows don’t seem to work but it works when I type in the radius :+1:
Scratch that the arrows work too! I just did it wrong at first :sweat_smile:
When you enter the value, do you enter the value per model or is it true (“paper space”) dimension?
What? Please clarify your question.
When you enter a dimension for the radius of the fillets, is that value the sheet scale or will it apply the model scale?
Unless you are in a scaled drawing, when you draw in Layout it is 1:1.
I’ve noticed a bug in 2026 at least whereby when you press the up and down arrow keys, the radius doesn’t “live” change like it used to. I have to wiggle the mouse to move the shape a bit before the radies size updated visibly.
But if you are in scaled drawing mode you still enter real world dimensions… so everything you draw in Layout is 1:1, no?
Nearly three years ago – I can’t think what my point was!
