How do I change the scale in Layout the default is in mm. I want to change the scale to 1/4" = 1’
HELP?
HELP?
Change the scale of what? The dimensions shown with the Dimension tool when adding dimensions in Paper Space? If so, you can set the scale in the Dimensions window.
When you are drawing in LO, the lengths of lines and such will always be given as paper space dimensions. You can change the units in Edit>Preferences but there is no scale to set.
for the embedded SketchUp model and in a non-perspective view only under “Window > SketchUp Model > View > Ortho > …”:
I set the scale in the dimension window but it will not save my changes or allow me to to make changes in the scale tray
Those dimension scales only impact scale settings for SketchUp model viewports.
Ok, all I was trying to accomplish was a layout and I wanted to add my own dimensions or draw it to scale in layout the size was 48’ x 40’ when I grab the dimension tab it dim’s it to the scale as drawn
Tim Larsen
Director of Technical Operations
Fabrication Division
AZCO INC.
P.O. Box 567
Appleton, WI 54912-0567
1025 E. South River Street
Appleton, WI 54915
p: 920-734-5791
www.azco-inc.comhttp://www.azco-inc.com
[AZCO-YLogo No Tagline tiny]
“Dedicated to Zero Injury”
THE INFORMATION CONTAINED IN THIS E-MAIL TRANSMISSION IS INTENDED ONLY FOR THE PERSONAL AND CONFIDENTIAL USE OF THE RECIPIENTS NAMED ABOVE. This message may be an attorney-client communication or contain trade secret information and, as such, is privileged and confidential. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this message in error, and that any review, dissemination, distribution or copying of this message is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message by e-mail. After replying to the message, please delete it from your computer. Thank you.
You should draw the layout in SketchUp and create a scene with the camera set to Parallel Projection. Save the file and send it to LayOut. Then you can set the viewport to your desired scale.
By the way, you might want to go to the SketchUp Community Forum and edit your previous post. It appears to have all your contact info from your e-mail.
