After updating from 2025 pro to 2026 pro Layout no longer updates scenes. The way I work is I create multiple scenes of the same view in Sketchup and hide groups/components in my sketchup scenes. Thus, I have a “master" scene that has all groups/components and depending on what I want in the scenes I hide select groups/components. Then in Layout I copy the same linked viewport on multiple pages. This has always worked until the update to 2026. It even happens when I open a past project. To clarify, when I update the scenes, it shows what the master looks like with all items visible. The only work around I found was to assign each item a tag other than unassigned and then switch off the unwanted tags in each Layout viewport.
Share the LO file so we can see exactly what you have set up.
How do I share it?
If it’s less than 16 Mb, drag the LayOut file into a reply. If it’s larger, upload it to DropBox and share the link.
Thanks for the quick response! I actually figured it out just now. Layout scene was not referencing correct Sketchup scene.
