I am new to Sketchup Pro and Layout. I am unable to change dimension units from decimal meter to architectural fractional. I see the dialog box but it is inactive. Any help would be much appreciated.
In order to make changes you need to either have the Dimension tool or an existing dimension selected first. It’s similar to making changes to other things like Text, Labels, Shapes, etc.
Thank you Dave. That did it! No where does it mention that.
Jeff Benson
Benson Designs, LLC
920-499-4027
Generally if you want to modify something you need to select it first. If you want to make changes to what a tool does, you need to select the tool first.
Might have a look at this page: Marking Dimensions | SketchUp Help
You may want to remove the personal information from your post.
