Layout Dim Lines not there
I have never had an issue with adding dimensions in layout. But in my current doc, on some of the pages, the dim tool only shows the number of the dimension not the leader lines. I have checked the layers and dim style panels and document set up dims section. Can’t figure it out.
Share the LayOut file so we can investigate.
What operating system? 2024 doesn’t identify an operating system. It would be either some version of Windows or Some version of Mac OS.
Hi Dave, did you resolve the issue for this?
I am having the same problem. The dimensions show the number but not the leader lines. It is baffling as the document I was working on was just fine and then the dimension problem started. I already added dimensions without any problem however now the leader lines won’t show (previous added dimensions still ok). using Mac OS 26.0 and SU 2024
Cheers
Martin
See attached screen shot for clarity.
As Dave suggested to the OP – can you share a file that has the problem…?
The OP never came back so no, I didn’t resolve it.
Please share your file. Maybe we can get to the bottom of it.
Hi the file is too large to share here. Let me see if I can reduce it or create a link
Don’t do that. Upload it to DropBox or We Transfer and share the link.
