LayOut Show lines not present in SketchUp
I see some lines in LayOut that are nos showing up in my SketchUp File, I have restarted and tried different workarounds with no luck Thanks
High Gate Guest House Bar.layout (12.5 MB)
High Gate Guest Pool Bar SK.skp (11.7 MB)
Which lines aren’t supposed to be showing in your screenshot?
If you are referring to this dark red line, that’s a leader from a label you added in SketchUp.
I used Select All Leader Text in Model Info>Text. Entity Info shows there are two.
After saving the changes and updating the referece in LO, the leader is gone.
BTW, there are a few other issues between your SU and LO files that ought to be fixed. If you are interested in dealing with them I’ll go through it for you.
Thanks Dave, I am missing one step. The leaders are not visible, I had created some leader but then delete them so I don;t know why they are there and not visible. How did you delete them?
And yes I would love to know all the issues between SU and LO. Thanks
As I wrote, I selected them using the “Select all leader text” button in Model Info>Text. Then I deleted them with the Delete key. You may have to set the focus back on the main window by clicking on the SketchUp title bar before hitting Delete.
I’ll make another post about the other things.
That was it! I wasn’t setting the focus back in the main window, I still don’t understand why they were showing in LO when they were not showing in SU. Thanks a lot!
