Layout cut fill issue
Hi. It is happening to me quite often and is very annoying and time consuming to resolve.
Actually left hand side showing sketchup screenshoot while right hand side one from layout
As you can see eg mid an bottom drawer front did not fill, same as top one. It looks like a glitch especially RH picture which showing sketchup model section appears correctly.
In same cases changing the size of the plane sections helps but not always. I have to have that in Vector render. I noticed if changed to raster - it would help but all getting blurry and usesless.
Appreciate any comment/advise/tips
Many thanks
Rob
Does it look blurry and useless when you export with high settings, or just when working in LO? The exported PDF should look better (even in raster) when settings are on high. But even on high it doesn’t look as great in LO as in the output.
(this happens to me once every 5-10 drawings. Sometimes it is faster to draw the shape in LO than try to figure out why it glitches)
I haven’t had this happen in any of my projects but I have seen a few cases in which others have. As Mike suggests, it’s often faster to just trace in the shape in LO and add a fill color to the shape. Another option is to use TIG’s SectionCutFace (from Sketchucation) to create actual faces at the section cut. I like this because the faces can have different materials including textures applied to them to help differentiate the parts. I did that for both of these examples.
Yes it looks blurry even settings are set on high.
I am having same as you - 5of10 or even more must be infilled manually.
I am still gonna call it as a software glitch. I’ve just purged this drawing and missing previously fields are not infilled…
I think it is related to size and complexity of drawing.
Thank you anyway
Thanks Dave.
I will try to use TIG’s SectionCutFace. It might be a good solution and complete drawing will get a better appearance.
Good deal.
Are you still using SketchUp 2023?
2026 - last few months
Please update your forum profile.
try Hybrid on that viewport instead of Vector. fills come out like Raster but the lines stay sharp. that usually sorts it with section fills
