Layout bug splat
When working in Layout, I keep getting the Bug splat and it is not a big drawing.
This is what it shows:
Crash #47281
A newer version of SketchUp is available that may resolve this crash. Please install any available updates to your SketchUp application under Help > Check for Updates.
Any fix to it?
Thank you.
Chris
Your profile says you are using SketchUp 2022. If that’s the case, update to the current version of SketchUp/LayOut like the message directs.
You could share the LO file. Maybe we can figure out what is happening.
Thank you Dave!!!
I also checked online for the fix and found that if I change Preferences in SU, in Graphic Setting from “Use new graphic engine” to “Classic graphics”, may help. So I did it, and so far, so good.
If I update to 2024, I guess I have to upload all the Extensions. Right? :confused:
Chris
Yes. Install the newest versions of the extensions so everything is up to date.
I have problems in exporting pdf files and image. I did already last update of sketchup vesion 24.0.954 64-bit, I already changed setting for old graphic engine, but the probelm is the same. No erros are comings. Please help. Thank you.
If you share a file you are having problems with, we can try to help…
