Layout and SVG
I ask the developers if the possibility of exporting and importing the SVG format is very planned in the graphic sector. Thank you
That would be nice. My experience is to work with .EPS files instead of .SVG. Easy export from Adobe Illustrator and LayOut reads eps fine.
You can export to PDF (with Vector rendering) , or to EPS and convert to SVG in a graphics application like Illustrator ($$$) or Inkscape (free).
Grazie, per la grafica vettoriale utilizzo Inkscape! :slight_smile:
We should have SVG export and import to LO… it is an open standard vector illustration format and in widespread use…
It seems to me that even EPS files are now not supported in Layout 2021? Why is there no vector image support? SVG would be perfect, but at least EPS should be available. Very unfortunate!
