Unistalled and re installed it.
I checked the scrapbooks file location
Ran as administrator
Checked that all updates to windows are current
Sketchup works
Style builder no problem
Only layout, right before deadline
Sketchup works
Hi-
I found one of your crash reports in our database. Try renaming or deleting this folder:
C:\Users\YOUR USERNAME\AppData\Roaming\SketchUp\SketchUp 2015\LayOut
Note that this folder is where scrapbooks, templates, and settings are stored, so if you have anything important saved here then don’t delete it - instead, rename the folder.
thanks,
Marc
Hi Marc
I tried deleting that folder but no luck.
When I try yo start Layout it creates it again
This is the expected behavior. Marc wanted Layout to rewrite all settings files back to factory defaults.
I see.
I did uninstall and then reinstalled the whole suite so all settings were already reset to default.
Any other ideas?
Thanks
It’s possible that I was looking at someone else’s crash report with a similar name. Can you tell me what name or email address you put on your crash reports?
Thanks,
Marc
I registered sketchup make with roquetomatis@hotmail.com but used a gmail acount for pro.
