I am working on reality and I am new to skethcup but not 3d modeling. I was wondering, how would I get landscape data/info say for miami beach? I would like ot get that data and try mideling it from a picture. I have heard of topo lines but I see now example of actually making a ral life scene of somewhere.
any info or advice would be really gratefull.
Note: this only works with Pro. It used to work with all older versions including Make, but now only works in Pro. I find this disappointing.
Below you can find a tutorial-like content on Importing DEM Files for Terrain.
This website has most of the terrain data worldwide: https://earthexplorer.usgs.gov/
1- Note that sign-up needed for downloading data.
2- Search for your location.
3- Choose “ASTER GLOBAL DEM” or “SRTM 1 Arc-Second Global” as your data. (Not sure which one is better but i think SRTM is newer)
4- If there are more than 1 option to choose, download GeoTIFF format (then convert it to USGS ASCII DEM file format that SketchUp reads natively with software called 3DEM. This software reads/converts/saves different types of height data and let’s you crop those data maps (When data is so huge, SketchUp crashes).
5- Import DEM file to SketchUp (don’t forget to click options and increase points number for higher detail)
You can clean the mesh with CleanUpÂł extension.
The source for the data does not supply it for free so it makes sense that only pro users would be able to access it.
