Hi. I have imported my contours from a dxf file and need to label each contour with the Z value from sea level. How do I go about this?
Thanks
Thanks
Try a text label?
If you click on an end point of a segment in the contour line when placing the label, I think it will even give you the x, y, z coordinates.
HI John
It only gives the Z coordinates with the model ie: level from 0mm. I need the value above sea level. If I geolocate the model the value is still not above sea level.
Any ideas?
Thanks
Jaco
No real idea, and not at computer at the moment to try anything.
Could you change the axis location in Z to give you the right height above sea level?
Maybe you should try TIG’s Add Height from Datum.
