Show spot height (elevation) labels?
Hi,
I’m trying to add labels to a plan that show what Z height each face or edge is at.
The height should be relative to the origin point of the component.
Preferably the points would be a little point or small component (a cube?) with a label attached. I’ve tried Trimble Field Points but that doesnt show the elevation.
Anybody know a method for doing this?
Thanks :slight_smile:
I believe TIG’s Add Height from Datum is what you are looking for.
https://sketchucation.com/forums/viewtopic.php?f=180&p=193424#p193238
It includes nice video.
Typically, this Z-height is referred as spot elevations.
Utilities Tools plugin has a Query Tool feature which does what you need but temporarily.
Point Gadget 2 does also what you need with more advanced options.
I made a component that looks like a level dimension arrow, with a dynamic attribute that converts its z-position into a height text. Then I can, in LayOut add a leader and label that refers to the attribute. I’d post a screenshot but the file is on my other computer that I cannot access right now.
This one works great. A nice simple level tag;
If it dynamically updated like Anssi’s component, then it would be truely fantastic.
