When installed version 2017, all shortcuts are missing, including these that should exist by default. How to import those from version 2016?
I solved the problem myself, so no reply needed. I exported Preferences.dat file from 2016 and imported it into 2017. Now it`s Ok.
Just so others know, your situation is not supposed to happen. SU is supposed to import your shortcuts from the previous version automatically. So, something went wrong during the installation (did you right-click “run as administrator” the installer?). In any case, what you describe is the workaround on WIndows (it does not apply on Mac).
There’s a reset option in the shortcut preferences that can be helpful in this case too.
