... just one more question
Is it possible, when using sections, to section only part of an image… I wanting to show a cross section of a hole under construction by a piling rig, but I don’t want the drilling tool sectioned when it’s shown in the hole…
Is this achievable using the section tool?
Cheers
N
Yes, that should be possible.
Fast tube search ‘sketchup section’ gave me this sample:
Hope this works for you?
I should just have a play with things before asking questions…
Thanks for the reply - that will be useful.
The solution to my task is to perform the section, then make it all a group. Anything added after is unaffected by the section…
This is just a test, but the effect is what I was looking for…
If it works, it works :slight_smile: :+1:
The point being that the section works within context, so if you open a group for editing and insert a section it will only slice within that groups context.
You don’t need to make the section first.
