Hi There I’m new here.
So I install the Joint Push Pull extension form the sketchucation extension. the tollbar didn’t show up and in the extension drop menu it didn’t show up as well.
I did a search on my c drive and I found the file with all the data and the graphic for the extension. how can I bring it to the App?
Joint Push Pull should show up in Tools menu>Fredo6 Collection submenu
Did you install the required LibFredo helper extension? Have you a license for Joint Push Pull?
In addition to what @Anssi says…
Also ensure you have the latest version of the SketchUcation toolset installed to get the current licensing set up etc [v4.2.9] and of course the latest versions of the extension itself and the Lib.
After everything is installed you need to restart SketchUp to get everything properly synced…
