I made a huge sketchup file and imported to layout 40 pages long, but once i finished them, i was told to use Vector rather than Raster style. However, when I changed to vector, the guidelines I used for dimension lines went missing. Is there a way to change all the guidelines to gridlines in one go?
xLine2Line by Tig. it’s an old code, but it (should) checks out.
it’ll ignore the infinite guidelines and only convert the normal ones to edges.
edit : I’m confused, you’re using sketchup 2022 with a sketchup for school licence ? man your crak is really outdated…
re-edit : it works in 26.
Hi! Thanks for the reply! I found that the plugin does work, but only with guidelines. Is there a way to make it work with guide point too? Or a plugin to change guidelines to guidepoint?
Also, that is what my school claimed…
I see. schools / highschools / universities have access to something called a LAB licence. it allows them to install sketchup pro active without a subscription.
it’s usually a long process, and they don’t necessary update every year.
in this case you’re in luck, the script is old enough to drink (in most of europe at least).
yep. nope ![]()
on sketchucation someone asked the same 10 years ago.
I can ping @TIG but I doubt he has a magic update in his hat. (try to repeat I can ping tig, it’s really hard)
the thing is, you’re not really supposed to use sketchup to add all your dimension, that’s why layout exists. dimensions in sketchup are here to help you while you work. same with guidelines. In layout, you add the dimensions that you plan on exporting, you can even set them up in a style that’ll mimic what you’ve done in sketchup
I have an 20 year old script that saves guidelines [then known as construction or xlines] so that you can’t delete them accidentally ‘globally’.
It does that by changing them to edges [aka lines].
You could perhaps use that to swap your guidelines for lines,
but of course there are limitations - e.g. an infinitely long guideline is not going to swap for an infinitely long line !
It works on selected set-length guidelines, from a context-menu item.
How are you making your guidelines ?
https://sketchucation.com/pluginstore?pln=xLine2Line
