HI.,
is it possible to create the guides like this, without the guide point.
How to do this kind of stuff.
Yes, with a plugin that converts edges into construction lines. (Can’t recall the name).
The inference engine finds them. Not the tail of a guidepoint.
Yes, that’s the one I mentioned.
added: construction line by daiku
https://extensions.sketchup.com/en/content/construction-line
There’s another that works differently but achieves the same result - CLineTool.rb.
AFAIK not in either Extension Warehouse or SketchUcation Plugin Store. It used to be obtainable from SketchUp Plugins and Blog: Plugin: Construction Line Tool but the download link there is not working.
Here’s the file: clinetool.rb (12.9 KB)
Copy the file into your Plugins folder, then restart Sketchup. It appears in the Draw menu as Construction Lines. I set up a shortcut to it - Shift+L.
You can directly draw guidelines, with an option to toggle endpoints on or off - tap the Option key (Mac) or Alt key (Windows) to invoke the toggle.
Thank you all…
