How to add a guide point
I want to add a guide point without a guide line. Can someone tell me how to do that? I thought there was an extension to do that.
I don’t believe you can add a guide point with the normal interface. The item is technically a “Construction Point” and can be created using the Ruby APIs (as is done in a number of extensions). You can paste the following line into the Ruby Console and it will create what is reported back as a “Guide Point” in the entity info pane:
Sketchup.active_model.active_entities.add_cpoint(Geom::Point3d.new(10,10,0))
@Wo3Dan probably has more to say about this topic …
Thanks for that suggestion.
I just answered my own question regarding an extension (which no doubt uses the function you mention). There is a plugin titled Pen Tool +
on Sketchucation. It does a bunch of cool things but amongst them is to let you easily input guide points (construction points)
You add a guide point by selecting the tape measure tool, clicking on a vertex, moving the cursor to where you want the point, and clicking again. If the new location is on the same edge as the start vertex, you will get just a guide point. If it is not, you will get a guide point with a dashed “tail” back to the reference point.
There is a free plugin on Smustard called Midpoint. It adds a construction point halfway between any two other points.
A. This is pretty handy all by itself.
B. You can move or copy the construction point.
-Gully
Open autocad. Put one dot. and Save. Insert this file into sketchup. That’s it.
Open SketchUp > Draw a Circle > Right click on edge > Find Center > Delete the circle. Guide Point
Or use a simple plugin like this one…
https://sketchucation.com/pluginstore?pln=PointTool
It’s over a decade old but it still works just fine…
Easier yet, just take the tape measure tool, start drawing a guide point from the origin, stop and type zero for the distance.
