Hiya.
I am new to the Community website, but not new to SketchUp as I had it for about three years, however due to not spending enough time working on SketchUp, I would have to consider myself still a novice. I’m familiar with the main tools, but not familiar with everything else. I’m familiar with the Follow Me command, but use it for something simple like pipes and wires.
To make it easier to explain what I am talking about, I have uploaded an exported 2D image of my model still in a WIP (Work In Progress) stage onto my DeviantArt page, so you could see what I am taking about. (The reason I posted on my DA page is because I’m also asking anyone on DA for advice, but figure maybe I should join this website you all are experienced (to various levels) on using SketchUp.)
The link is https://www.deviantart.com/airfixnikon/art/WIP-Eject-Seat-02-788454875
I have done the ejector seat so far. I should point out that it is a sci-fi ejector seat so not really trying to create a modern day ejector seat. As you can see from my example, I’ve got some clips and housing already done. The clips are in their housing. All that is needed is to create belt straps between the clips.
I know it is a 3D image, and I am not trying to get a really prefect flow, not looking for prefect smooth curves, however I don’t want a too straight looking straps that makes them look like bars. I tried two options and made a dog’s dinner of both attempts, unless I have been doing it wrong or missed a trick.
First attempt. Tried to use the Follow Me command, but it made them look like bars instead of a curvy strap. Also the rectangle end of the strap ended up not lined up with the rectangle end of the clips.
Second attempt. Tried to draw a rectangle, use the Push/Pull command to pull and create a segment, repeat the action, and along the way, sometimes needed to use the Move or the Rotate commands to move each segments so that it could look just good enough to go around what would normally be the pilot’s body shape.
When I mention segments, maybe to make it easier to explain, let’s use an analogy as an example, let’s just say, looking like tank tracks.
I haven’t got any ideas of how best to create belt straps. So hopefully someone could suggest which course of action is more effect.
Many thanks.
