Hey there!
I was wondering if there is a quick mode to hide/show the quotes, annotations, and dimensions made with the Dimension tool like this, instead of selecting them and erase them. Or putting then into a particular layer. Like one can do it with “guides”
Turn off units display in Model Info, Units. You can’t hide the entire dimension text without hiding the dimension lines, if that’s what you are asking. The dimensions can be given a tag if you don’t want to see them at all.
No, i want them to dissapear completely xD the dimension lines, the number, everything. I am aware that they can be given a tag but sometimes i receive models filled with dimmensions and without a tag, so i have to delete them one by one
If you don’t need those dimensions at all, why don’t you just give them a tag and turn it off? You can easily select all dimensions in the same context with the button in Model Info>Dimensions and then give them a tag in Entity Info.
As i said before, most designs i have to process wasnt made by me, so in order to put a tag on each dimmension to delete them all…its barely the same to delete them each of them.
